Joined
Looking for anyone who has successfully fitted 255/35R20 on 20 X 9 rims with +32mm offset on the front end of Stinger GT2 AWD.
Be a Hero and let me know! Eh?
Cheers
Cheers
Unless of course its a front wheel drive vehicle which in that case it make sense to have wider tires in the front if grip is really that important to someone but too often FWD drivers swap on a wheel/tire set that's more suitable for RWD applications.I'd assume most sports cars have larger/wider rears instead of the front though staggered with larger in front may increase lateral traction. Would need some re-calibration and i would probably change out the rears as well.
Even if someone gets AWD they're not limited in what they can do, if they wanted wider wheels with a deeper offset, maybe now they can just do that to all 4 wheels.Well the Stinger is offered in either rear- or all-wheel drive, so it's best to go with larger rears if you're really into the mod and you have a RWD. Otherwise it's probably better to stick with a four tires of he same size.
Fact is you shouldn't because the only benefit is with looks. It might look good but doesn't accomplish anything in terms of performance. Not to mention all the people that will laugh at you.Of course you're not limited to just one size when it comes to the AWD Stinger, but the original question was if you can have larger tires up front and smaller in the rear. Which doesn't really make much sense to me when you have an AWD car.
If that's the case then you should be more conscious about where and how you drive because that alone can be what's bending rims. The alternative is to just get a smaller wheel (18 inch) with a thicker tire to absorb the impact from the roads around you. Hopefully that helps.Question about rims on the GT2. Has anyone had problems with bent rims yet? I'm seriously considering a GT2 before the end of the year but I'm a little gun shy of the 19" wheels. Had that on my Buick LaCrosse Touring and lost count of the repaired and replaced rims. Any input is greatly appreciated!
